HP ZBook 15 Intel Core i7-6820HQ 15.6 8GB 256GB 15.6" Wi...
HP ZBook 15 Intel Core i7-6820HQ 15.6 8GB 256GB 15.6" Windows 7 Pro
£2,774.61
Delivery:
Key features
  • Configure the workstation that that fits your work style with choices of memory processor, graphics and more.
  • The HP ZBook 15 has been redesigned inside and out and is now 27% thinner and 15% lighter than the previous generation.
  • Work confidently knowing 30 years of HP Z DNA and extensive testing went into the development of the HP ZBook 15.
Product codes
Work almost anywhere on the HP ZBook 15 mobile workstation. Its mobility and robust configurability, create a powerful mix of style, features, and portability in a thin, light, 39,6 cm (15.6") diagonal form factor.
Impress and perform
HP's most popular mobile workstation has been redesigned, inside and out. Now 27% thinner and 7% lighter than the previous generation, it offers 100% more wow--it's designed to impress and perform.
Create your ideal workstation
Configure the HP ZBook 15 with Intel® Xeon® processor options, up to 64 GB ECC memory, dual 1 TB HP Z Turbo Drive G22 3 for up to 3 TB4 of total storage, dual Thunderbolt™ 3, and optional HP DreamColor UHD or FHD touch displays.
Defined by HP Z DNA
Work confidently with HP mobile workstations designed around 30 years of HP Z DNA with extensive ISV certification. It’s reliable, designed to pass MIL-STD 810G testing, and endure 120K hours of testing in HP's Total Test Process.
Product Description HP ZBook 15 G3 Mobile Workstation - 15.6" - Core i7 6820HQ - 8 GB RAM - 256 GB SSD - UK
Product Type Notebook
Operating System Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor Intel Core i7 (6th Gen) 6820HQ / 2.7 GHz (3.6 GHz) / 8 MB Cache /
Memory 8 GB DDR4 (2 x 4 GB)
Storage 256 GB SSD HP Z Turbo Drive G2
Optical Drive No optical drive
Display 15.6" LED backlight 1920 x 1080 / Full HD
Graphics NVIDIA Quadro M2000M
Video Memory 4 GB GDDR5 SDRAM
Input Device Pointing stick
Keyboard UK
Keyboard Backlight Yes
Numeric Keypad Yes
Integrated Webcam Yes
Networking 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
Battery 9-cell
Security Trusted Platform Module (TPM 1.2) Security Chip, smart card reader
Colour Graphite, hematite
Dimensions (WxDxH) 38.6 cm x 26.4 cm x 2.6 cm
Weight 2.59 kg
Localisation Language: English / region: United Kingdom
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - parts and labour - 3 years
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP ZBook 15 Intel Core...
£2,774.61
