General |
Product Type |
Notebook |
Operating System |
Windows 10 Pro 64-bit Edition - English |
Processor / Chipset |
CPU |
Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed |
3.1 GHz |
Number of Cores |
Dual-Core |
Cache |
3 MB |
64-bit Computing |
Yes |
Features |
Hyper-Threading Technology, Intel Smart Cache, Intel Burst Technology 2.0 |
Memory |
RAM |
8 GB (1 x 8 GB) |
Max RAM Supported |
32 GB |
Technology |
DDR4 SDRAM - non-ECC |
Speed |
2133 MHz / PC4-19200 |
Rated Speed |
2400 MHz |
Form Factor |
SO-DIMM 260-pin |
Slots Qty |
2 |
Empty Slots |
1 |
Storage |
Main Storage |
256 GB SSD - (M.2 2280) PCIe - NVM Express (NVMe) |
Display |
Type |
15.6" - IPS |
LCD Backlight Technology |
LED backlight |
Resolution |
1920 x 1080 (Full HD) |
Widescreen |
Yes |
Image Brightness |
340 cd/m² |
Features |
Slim Design, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare, 157 ppi |
Keyboard Name |
HP Collaboration |
Audio & Video |
Graphics Processor |
AMD Radeon Pro WX 3100 / Intel HD Graphics 620 |
Video Memory |
2 GB |
Camera |
Yes - 720p |
Video Resolutions |
1280 x 720 |
Frame Rate |
30 frames per second |
Camera Features |
720p HD movie recording, IR camera, low light enhancement, Windows Hello |
Sound |
Stereo speakers, dual array microphone |
Compliant Standards |
High Definition Audio |
Audio Features |
Bang & Olufsen Audio |
Input |
Type |
Keyboard, pointing stick, ClickPad |
Keyboard Backlight |
Yes |
Keyboard Layout |
UK |
Numeric Keypad |
Yes |
Features |
Spill-resistant, multi-touch clickpad |
Communications |
Wireless |
802.11a/b/g/n/ac, Bluetooth 4.2 |
Bluetooth Class |
Class 2 |
Wireless Controller |
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2) |
Network Interface |
Gigabit Ethernet |
Ethernet Controller |
Intel I219-V |
Remote Management Protocol |
SNMP 2 |
Features |
Wake-on-LAN (WOL) |
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az |
Battery |
Technology |
3-cell lithium polymer |
AC Adapter |
Input |
AC 120/230 V (50/60 Hz) |
Output |
65 Watt, 19.5 V |
Connections & Expansion |
Interfaces |
USB 3.0 (charging) , Thunderbolt 3 , USB 3.0 , Headphone/microphone combo jack , LAN , HDMI , Dock |
Memory Card Reader |
Yes (SD Card, SDHC Card, SDXC Card) |
Miscellaneous |
Colour |
Turbo silver |
Case Material |
Aluminum |
Dockable |
Yes |
Security |
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader |
Features |
HP DuraKeys, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3, Master Boot Record Security |
Theft/Intrusion Protection |
Security lock slot (cable lock sold separately) |
Security Slot Type |
Kensington security slot |
Included Accessories |
Power adapter |
CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, KCC, WEEE, A-Tick, ICES |
Localization |
Language: English / region: United Kingdom |
Dimensions & Weight |
Dimensions (WxDxH) |
37.08 cm x 25.1 cm x 1.86 cm |
Weight |
1.77 kg |
Manufacturer Warranty |
Service & Support |
Limited warranty - parts and labour - 3 years |
Environmental Parameters |
Min Operating Temperature |
0 °C |
Max Operating Temperature |
35 °C |
Humidity Range Operating |
10 - 90% (non-condensing) |
Shock Tolerance (operating) |
40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) |
200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) |
0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) |
1.5 g @ RMS (random) |
