General |
Product Type |
Notebook |
Operating System |
Windows 10 Pro 64-bit Edition - English |
Processor / Chipset |
CPU |
Intel Core i7 (8th Gen) 8650U / 1.9 GHz |
Max Turbo Speed |
4.2 GHz |
Number of Cores |
Quad-Core |
Cache |
8 MB |
64-bit Computing |
Yes |
Features |
Intel Turbo Boost Technology 2.0 |
Memory |
RAM |
32 GB (2 x 16 GB) |
Max RAM Supported |
32 GB |
Technology |
DDR4 SDRAM - non-ECC |
Speed |
2400 MHz / PC4-19200 |
Rated Speed |
2400 MHz |
Form Factor |
SO-DIMM 260-pin |
Slots Qty |
2 |
Empty Slots |
0 |
Storage |
Main Storage |
1 TB SSD - (M.2 2280) PCIe - NVM Express (NVMe) |
Display |
Type |
15.6" - IPS |
LCD Backlight Technology |
LED backlight |
Resolution |
1920 x 1080 (Full HD) |
Widescreen |
Yes |
Image Brightness |
340 cd/m² |
Features |
Slim Design, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare, 157 ppi |
Audio & Video |
Graphics Processor |
AMD Radeon Pro WX 3100 / Intel HD Graphics 620 |
Video Memory |
2 GB |
Camera |
Yes - 720p |
Video Resolutions |
1280 x 720 |
Frame Rate |
30 frames per second |
Camera Features |
720p HD movie recording, IR camera, low light enhancement, Windows Hello |
Sound |
Stereo speakers, dual array microphone |
Compliant Standards |
High Definition Audio |
Audio Features |
Bang & Olufsen Audio |
Input |
Type |
Keyboard, pointing stick, ClickPad |
Keyboard Backlight |
Yes |
Keyboard Layout |
UK |
Numeric Keypad |
Yes |
Features |
Volume control, waterproof, spill-resistant, multi-touch clickpad |
Communications |
Wireless |
802.11a/b/g/n/ac, Bluetooth 4.2 |
Bluetooth Class |
Class 2 |
Wireless Controller |
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2) |
Network Interface |
Gigabit Ethernet |
Ethernet Controller |
Intel I219-V |
Remote Management Protocol |
SNMP 2 |
Features |
Wake-on-LAN (WOL), dual stream (2x2) |
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az |
Battery |
Technology |
3-cell lithium polymer |
Capacity |
56 Wh |
Run Time |
Up to 10 hours |
AC Adapter |
Input |
AC 120/230 V (50/60 Hz) |
Output |
65 Watt, 19.5 V |
Connections & Expansion |
Interfaces |
USB 3.0 (charging) , USB-C 3.1/Thunderbolt 3/DisplayPort , USB 3.0 , Headphone/microphone combo jack , LAN , Dock |
Software |
Software Included |
Skype, LANDesk Management Suite, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, Password Manager, Windows Defender, Device Access Manager, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, HP Security Manager, HP BIOS Configuration Utility (free download), HP Credential Manager, HP Client Catalogue (free download), Absolute Persistence, HP Driver Packs, HP 3D DriveGuard 6, HP Image Assistant, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP LAN-WLAN Protection, HP Client Security Suite Gen3, HP BIOSphere Gen3, Native Miracast, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP Workwise (free download), CyberLink Power Media Player CMIT, HP Fingerprint Sensor, Power On Authentication |
Miscellaneous |
Colour |
Turbo silver |
Case Material |
Aluminum |
Dockable |
Yes |
Security |
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader |
Features |
HP 3D DriveGuard, HP DuraKeys, soft-touch surface, HP BIOS Protection, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3, Master Boot Record Security |
Theft/Intrusion Protection |
Security lock slot (cable lock sold separately) |
Security Slot Type |
Kensington security slot |
Included Accessories |
Power adapter |
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, KCC, WEEE, A-Tick, ICES, Common Criteria EAL4+, low halogen |
Localization |
Language: English / region: United Kingdom |
Dimensions & Weight |
Dimensions (WxDxH) |
37.08 cm x 25.1 cm x 1.86 cm |
Weight |
1.77 kg |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Manufacturer Warranty |
Service & Support |
Limited warranty - parts and labour - 3 years |
Environmental Parameters |
Min Operating Temperature |
0 °C |
Max Operating Temperature |
35 °C |
Humidity Range Operating |
10 - 90% (non-condensing) |
Shock Tolerance (operating) |
40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) |
200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) |
0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) |
1.5 g @ RMS (random) |
