On the go creativity knows no limits with a vivid 43,94 cm (17.3") diagonal HP ZBook 17 G2. Showcase your best work in the office or on the go and take advantage of HP's most powerful processing, graphics, simple scalability, and blazing-fast connectivity to perform and collaborate at the speed of creativity.
Refuse to limit your potential
Experience the ultimate in mobile workstation performance with the HP ZBook 17 G2.
One workstation for the office and the field
At the office or on the go the 43,94 cm (17.3") diagonal HP ZBook 17 G2 provides a scalable solution to workstation computing and remains easy enough to take where work sends you.
Be color confident
What you see is what you get with the optional HP DreamColor display on the HP ZBook 17 G2. Maintain accurate, predictable colors that are true to the finished product and consistent across your entire digital workflow.
Product Description | HP ZBook 17 G2 Mobile Workstation - 17.3" - Core i7 4910MQ - 32 GB RAM - 512 GB SSD + 512 GB SSD - UK | Product Type | Notebook | Operating System | Win 7 Pro 64-bit (downgrade from Windows 10 Pro) + Windows 10 Pro Licence - English | Processor | Intel Core i7 (4th Gen) 4910MQ / 2.9 GHz (3.9 GHz) / 8 MB Cache | Memory | 32 GB DDR3L (4 x 8 GB) | Storage | 512 GB SSD HP Z Turbo Drive + 512 GB SSD | Optical Drive | Blu-ray Writer | Display | 17.3" LED backlight 1920 x 1080 / Full HD | Graphics | NVIDIA Quadro K5100M | Video Memory | 8 GB GDDR5 SDRAM | Input Device | Pointing stick | Keyboard | UK | Keyboard Backlight | Yes | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet | Battery | 8-cell | Dockable | Yes | Security | Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader | Colour | Graphite, hematite | Dimensions (WxDxH) | 41.6 cm x 27.2 cm x 3.4 cm | Weight | 3.46 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 3 years - carry-in , Limited warranty - battery - 3 years |
General | |
Operating System | Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence - English |
Processor / Chipset | |
CPU | Intel Core i7 (4th Gen) 4910MQ / 2.9 GHz |
Max Turbo Speed | 3.9 GHz |
Number of Cores | Quad-Core |
Cache | L3 - 8 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel QM87 Express |
Platform Technology | Intel vPro Technology |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 32 GB (4 x 8 GB) |
Max RAM Supported | 32 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz |
Form Factor | SO-DIMM 204-pin |
Slots Qty | 4 |
Empty Slots | 0 |
Storage | |
Main Storage | 512 GB SSD PCIe - HP Z Turbo Drive |
Secondary Storage | 512 GB SSD SATA 6Gb/s |
Optical Drive | BD-RE removable - tray |
Display | |
Type | 17.3" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Features | Full HD ultra wide-viewing angle (UWVA) anti-glare DreamColor, Multi-Stream transport (MST) |
Audio & Video | |
Graphics Processor | NVIDIA Quadro K5100M |
Video System Features | NVIDIA Optimus |
Camera | Yes - 1280 x 720 |
Camera Features | 720p HD movie recording, low light enhancement |
Sound | Stereo speakers, stereo microphone |
Codec | IDT 92HD91 |
Compliant Standards | High Definition Audio, DTS Studio Sound, DTS SOUND+ |
Input | |
Type | Keyboard, touchpad, pointing stick |
Keyboard Layout | UK |
Features | Volume control, spill-resistant, touchpad with gesture support |
Communications | |
Wireless | Bluetooth 4.0, 802.11a/b/g/n/ac |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Dual Band Wireless-AC 7260 - PCI Express Half Mini Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I217-LM |
Remote Management Protocol | SNMP 2 |
Features | Wake-on-LAN (WOL) |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az |
Battery | |
Technology | 8-cell Lithium Ion |
Installed Qty | 1 |
Max Supported Qty | 2 |
Capacity | 75 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 200 Watt, 19.5 V |
Connections & Expansion | |
Expansion Bays | 1 x Upgrade Bay |
Slots | 1 x ExpressCard/54 (1 free) |
Interfaces | VGA , DisplayPort , Thunderbolt 2 , Headphone/microphone combo jack , LAN , 3 x USB 3.0 , USB 2.0 , Battery , Dock |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card) |
Software | |
Software Included | Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, HP Performance Advisor, CyberLink YouCam BE, Foxit PhantomPDF Express, Device Access Manager with Just In Time Authentication, HP Systems Software Manager (free download), HP PageLift, HP Security Manager, Box.net 50GB storage, Drive Encryption, HP Manageability, HP Validity Fingerprint Driver, HP Client Security Manager |
Miscellaneous | |
Case Material | Magnesium-aluminum alloy |
Dockable | Yes |
Features | Security lock slot (cable lock sold separately), Intel Anti-Theft Technology (iAT), HP 3D DriveGuard, Intel Active Management Technology (iAMT), HP DuraFinish, HP SpareKey, One-Step Logon, HP File Sanitizer, HP DuraCase, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port |
Included Accessories | Power adapter |
Compliant Standards | ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 3.46 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - carry-in , Limited warranty - battery - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
