HP ZBook 17 G2 Mobile Workstation Intel Core i7 4910MQ 16GB 512
£5,224.78
Delivery:
Key features
  • At the office or on the go the 43,94 cm (17.3”) diagonal HP ZBook 17 G2 provides a scalable solution to workstation computing and remains easy enough to take where work sends you.
  • Experience the ultimate in mobile workstation performance with the HP ZBook 17 G2.
  • What you see is what you get with the optional HP DreamColor display on the HP ZBook 17 G2. Maintain accurate, predictable colors that are true to the finished product and consistent across your entire digital workflow.
Product codes
On the go creativity knows no limits with a vivid 43,94 cm (17.3") diagonal HP ZBook 17 G2. Showcase your best work in the office or on the go and take advantage of HP's most powerful processing, graphics, simple scalability, and blazing-fast connectivity to perform and collaborate at the speed of creativity.
Refuse to limit your potential
One workstation for the office and the field
At the office or on the go the 43,94 cm (17.3") diagonal HP ZBook 17 G2 provides a scalable solution to workstation computing and remains easy enough to take where work sends you.
Be color confident
What you see is what you get with the optional HP DreamColor display on the HP ZBook 17 G2.1 Maintain accurate, predictable colors that are true to the finished product and consistent across your entire digital workflow.
Product Description HP ZBook 17 G2 Mobile Workstation - 17.3" - Core i7 4910MQ - 16 GB RAM - 256 GB (2x) SSD + 512 GB SSD - UK
Product Type Notebook
Operating System Win 7 Pro 64-bit (downgrade from Windows 10 Pro) + Windows 10 Pro Licence - English
Platform Technology Intel vPro Technology
Processor Intel Core i7 (4th Gen) 4910MQ / 2.9 GHz (3.9 GHz) / 8 MB Cache
Memory 16 GB DDR3L (2 x 8 GB)
Storage 1.024 TB: 2 x 256 GB SSD HP Z Turbo Drive + 512 GB SSD
Optical Drive Blu-ray Writer
Display 17.3" LED backlight 1920 x 1080 / Full HD
Graphics NVIDIA Quadro K4100M / Intel HD Graphics 4600
Video Memory 4 GB GDDR5 SDRAM
Input Device Pointing stick
Keyboard UK
Keyboard Backlight Yes
Numeric Keypad Yes
Integrated Webcam Yes
Networking Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
Battery 8-cell
Dockable Yes
Security Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Colour Graphite, hematite
Dimensions (WxDxH) 41.6 cm x 27.2 cm x 3.4 cm
Weight 3.46 kg
Localisation Language: English / region: United Kingdom
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - 3 years - carry-in , Limited warranty - battery - 3 years
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP ZBook 17 G2 Mobile...
£5,224.78
