Get the performance of a desktop with the freedom of a laptop. Get relentless performance when editing multiple streams of content, manipulating data and developing in VR.
Product Description | HP ZBook 17 G5 Mobile Workstation - 17.3" - Core i7 8750H - 8 GB RAM - 1 TB HDD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache | Memory | 8 GB DDR4 (1 x 8 GB) | Storage | 1 TB HDD / 7200 rpm + 16 GB SSD cache (M.2) (3D Xpoint (Optane)) | Optical Drive | No optical drive | Display | 17.3" LED backlight 1920 x 1080 / Full HD | Graphics | Intel UHD Graphics 630 | Input Device | Pointing stick, ClickPad | Keyboard | UK | Keyboard Backlight | Yes | Numeric Keypad | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet | Battery | 6-cell | Features | Ambient light sensor | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader | Colour | Turbo silver | Dimensions (WxDxH) | 41.6 cm x 28.8 cm x 3.35 cm | Weight | 3.2 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 8750H / 2.2 GHz |
Max Turbo Speed | 4.1 GHz |
Number of Cores | 6-core |
Cache | L3 - 9 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0, Intel Optane Memory Supported |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 64 GB |
Technology | DDR4 SDRAM - non-ECC |
Speed | 2666 MHz |
Rated Speed | 2666 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 4 |
Empty Slots | 3 |
Storage | |
Main Storage | 1 TB HDD SATA 6Gb/s / 7200 rpm |
SSD Cache | 16 GB 3D Xpoint (Optane) (M.2) |
RAID Level | RAID 0, RAID 1 |
Display | |
Type | 17.3" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Brightness | 300 cd/m² |
Features | 72% sRGB colour gamut, Full HD eDP anti-glare |
Keyboard Name | HP Premium Collaboration Keyboard |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 630 |
Sound | Stereo speakers, dual array microphone |
Compliant Standards | High Definition Audio |
Audio Features | Bang & Olufsen Audio, HP Clear Sound Amp |
Input | |
Type | Keyboard, pointing stick, ClickPad |
Keyboard Layout | UK |
Features | Volume control, spill-resistant, ClickPad with gesture support |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 5.0 |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Wireless-AC 9560 - PCI Express Mini Card (M.2) |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-LM |
Remote Management Protocol | SNMP 2 |
Features | Miracast, Wake-on-LAN (WOL), dual stream (2x2) |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az |
Battery | |
Technology | 6-cell lithium polymer |
Capacity | 95.6 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 200 Watt, 19.5 V |
Connections & Expansion | |
Interfaces | 2 x USB 3.0 , USB 3.0 (charging) , LAN , Mini DisplayPort , HDMI , 2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort 1.3 , Headphone/microphone combo jack |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card) |
Software | |
Software Included | Skype, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, Windows Defender, Device Access Manager, HP Velocity, HP Security Manager, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP 3D DriveGuard, HP Mobile Connect Pro, HP Image Assistant, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP LAN-WLAN Protection, HP Client Security Suite Gen3, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP System Software Manager (free download), HP BIOSphere Gen4, HP Host Based MAC Address Manager, HP SureStart Gen4 |
Miscellaneous | |
Case Material | Aluminum, magnesium alloy |
Integrated Options | Ambient light sensor |
Features | HP DuraKeys, Automatic DriveLock, HP DriveLock, Measured Boot, Power On Authentication, Pre-boot Authentication, Master Boot Record Security, BIOS Update via Network, HP Sure Click |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | ACPI, CSA, UL, FCC, RoHS, WEEE, low halogen |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 3.2 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
