HP ZBook Dock with Thunderbolt 3
Key features
  • Get stunningly easy setup on a dock that is small enough to take with you. Slip the dock into your briefcase and initiate charging, expansion, and wired networking with one cable.
  • Have a lot to attach? No problem! Link up to 10 devices at once through ports that include Thunderbolt™ 3 (which also supports DisplayPort 1.2 and USB 3.1 Gen 2), four USB 3.0, RJ-45, VGA, combo audio, and two additional DisplayPorts.
  • Proudly display this sleek and efficient solution in the office, or tuck it away and clean up your workspace for good. Either way, no more cables and no more clutter to worry about.
  • Rapidly replenish your HP ZBook’s power after a demanding day with an impressive charging station that passes power directly through a Thunderbolt™ 3 power cable to your HP ZBook.
  • Take multi-tasking to the extreme with support for two UHD/4K displays that are ready to broadcast every color and detail of your projects through a superfast bandwidth connection as soon as you plug into to the dock.
Product codes
Create a remarkably powerful and streamlined mobile workstation workspace without the clutter with the HP ZBook Dock with Thunderbolt 3. Get expansive device, display, and network connectivity plus simultaneous charging of your system through one simple cable from the dock to your HP ZBook.
HP ZBook Dock with Thunderbolt 3 - docking station - VGA, 2 x DP
Docking station
Video Interfaces
VGA, 2 x DP
23 cm x 5.7 cm x 1.6 cm
227 g
English / United Kingdom
Power adapter 150 Watt
EliteBook 1050 G1, 850 G5; ZBook 15 G3 Mobile Workstation, 15 G4 Mobile Workstation, 15v G5 Mobile Workstation, Studio G3 Mobile Workstation, Studio G4 Mobile Workstation, Studio G5 Mobile Workstation, Studio x360 G5 Mobile Workstation
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP ZBook Dock with Thu...
