HP ZVR Virtual Reality Display 3D LED 23.6" Monitor
£5,492.13
Delivery:
Key features
  • Experience real-time, natural interaction with your 3D content as the display follows the movement of your lightweight, passive glasses.
  • Immerse yourself in every detail of the holographic image with the stylus pen.
  • Project your 3D models to a 2D big screen with choice of third-party hardware.
Product codes
Change the way you think, work, and create with the HP Zvr 59,94 cm (23.6') Virtual Reality Display, the first commercial 3D display from HP that delivers a virtual-holographic 3D image so you can see every angle and curve in lifelike detail.
Product Description HP Zvr Virtual Reality Display - 3D LED monitor - Full HD (1080p) - 23.6"
Device Type LED-backlit LCD monitor - 23.6"
3D Capable Yes (3D glasses included)
Features Stylus, 4 x IR cameras, USB 2.0 hub
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 120 Hz
Pixel Pitch 0.272 mm
Brightness 200 cd/m²
Contrast Ratio 1000:1
Colour Support 16.7 million colours
Input Connectors DVI-D, DisplayPort
Display Position Adjustments Height, tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 69 cm x 28.29 cm x 52.53 cm
Weight 9.1 kg
Localisation English / United Kingdom
Compliant Standards Plug and Play, FCC Class A certified, CSA, UL
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP ZVR Virtual Reality...
£5,492.13
