HTC Vive Pro Starter Kit
LIMITED TIME OFFER
PRICE DROP
SALE! WAS £1,660!
Key features
  • Form-fitting comfort
  • Real-world awareness
  • Easily adjustable
  • Navigate naturally
  • Seamless interaction
Product codes
Spectacular sights. Hi-Res sound. Unrivaled immersion.
Crossing Realities
True-to-life precision room-scale tracking via SteamVR 1.0 base stations and controllers. Ultra-vibrant screen colours. Incredibly high contrast and uber-realistic sounds. VIVE Pro is engineered for professional-grade VR.
Spot Every Detail - High Resolution AMOLED Screens
See the difference with VIVE Pro. High resolution AMOLED screens, with super-rich colours and contrast, dazzle the eye and bring your imagination to life.
Designed for Comfort - Optimized Ergonomics
Optimized from top down for ergonomic comfort. Headset weight is evenly distributed to achieve a balanced centre of gravity. Suits a wide range of head shapes and sizes and is adjustable for different pupillary distances. VIVE Pro is ideal for extended sessions in VR.
Up to 3.5m X 3.5m Room-Scale Stage
Teleport around boundless virtual worlds sitting at your desk, or create a dedicated room-scale play area where you can physically walk around. SteamVR™ Tracking provides the best experience possible, so play the way that works for you – seated, standing or room-scale.
High-res Soundstage - 3D Spatial Audio
Hear every world as intended by its creator. The Hi-Res certified HMD and headphones are now integrated with 3D spatial sound to deliver for true-to-life immersive audio. The powerful amplifier is capable of driving high-impedance headphones - creating soundscapes that will change your world. The dual microphones allow for active noise cancellation as well as enabling Alert Mode and Conversation Mode - so you hear your surroundings while being immersed in any realities without the need of taking off the headset.
Fully Immersive
Precise, 360-degree controller and headset tracking, realistic graphics, directional audio and HD haptic feedback mean realistic movement and actions in the virtual world. It doesn’t get more first-person than this.
Product Description HTC VIVE Pro Starter Kit - 3D virtual reality headset
Device Type Virtual reality headset
3D Capable Yes
Features 2 microphones
Sensors Proximity sensor, gyro sensor, G-sensor, IPD sensor
Native Resolution 2880 x 1600 at 90 Hz
Resolution per Eye 3.5" - 1440 x 1600
Field of View 110°
Input Connectors DisplayPort
Compliant Standards DisplayPort 1.2
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
