Feel the thrust of power and speed in your palm with the Honor Play. Speed is what defines today's times and power is something inherent in you. Honor Play's fast processor gives you an experience like never before.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
Product Description | Honor Play - blue - 4G - 64 GB - GSM - smartphone | Product Type | Smartphone 4G | Display | LCD display - 2340 x 1080 pixels - 6.3" - LTPS | Features | Front-facing camera, dual rear-facing camera, digital player | Processor | Hisilicon Kirin 970 (8-core) - 64-bit | Memory | 64 GB - RAM 4 GB + microSDXC slot - up to 256 GB | Operating System | Android 8.1 Oreo with HUAWEI Emotion UI 8.2 | Rear Camera | 16 Megapixel focus: automatic | Second Rear Camera | 2 Megapixel | Front Camera | 16 Megapixel | Service Provider | Not specified | SIM Card Type | Nano SIM | SIM Card Qty | Dual-SIM | Wireless Interface | NFC, Wi-Fi, Bluetooth | Security Devices | Fingerprint reader, face recognition | Messaging Services | SMS, MMS | Connectors | 3.5 mm headset jack, USB-C | Colour | Blue | Dimensions (WxDxH) | 74.27 mm x 7.48 mm x 157.91 mm | SAR | 1.29 W/kg (body) / 0.8 W/kg (head) | Manufacturer Warranty | 2-year warranty |
General | |
Product Type | Smartphone |
Form Factor | Touch |
Integrated Components | Front-facing camera, voice recorder, navigation, dual rear-facing camera, digital player |
Width | 74.27 mm |
Depth | 7.48 mm |
Height | 157.91 mm |
Body Colour | Blue |
SAR Value | 1.29 W/kg (body) / 0.8 W/kg (head) |
Cellular | |
Technology | WCDMA (UMTS) / GSM |
Mobile Broadband Generation | 4G |
Operating System | Android 8.1 Oreo |
User Interface | HUAWEI Emotion UI 8.2 |
Navigation | GPS, A-GPS, GLONASS, BeiDou |
SIM Card Configuration Details | Nano SIM + nano SIM/microSD |
Input Device | Multi-touch |
Messaging & Internet | |
Supported Social Networks and Blogs | Yes |
Communications | |
Data Transmission | GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE, VoLTE, FDD-LTE, TDD-LTE |
2G Band | GSM 850/900/1800/1900 |
Wireless Interface | NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.2 |
Phone Features | |
Phone Functions | Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert |
Sensors | Ambient light sensor, proximity sensor, digital compass, gyro sensor, gravity sensor |
Additional Features | Face Unlock |
Processor | |
Type | Hisilicon Kirin 970 |
Processor Core Qty | 8-core |
64-bit Architecture | Yes |
Memory | |
RAM | 4 GB |
Internal Memory Capacity | 64 GB |
Supported Flash Memory Cards | microSDHC, microSDXC - up to 256 GB |
Front Camera | |
Sensor Resolution | 16 Megapixel |
Rear Camera | |
Focus Adjustment | Automatic |
Light Source | LED light |
Second Rear Camera | |
Sensor Resolution | 2 Megapixel |
Display | |
Type | LCD display |
Technology | LTPS |
Diagonal Size | 6.3" |
Display Resolution | 2340 x 1080 pixels |
Display Format | Full HD+ |
Colour Depth | 16.7 million colours |
Features | Honor Full View Display |
Connections | |
Connector Type | USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm |
Battery | |
Capacity | 3750 mAh |
Fast Charging Technology | Honor SuperCharge |
Miscellaneous | |
Included Accessories | Headset, power adapter, SIM card removal tool, USB-C cable, protective case |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
