Huawei Mate 20 Pro 6.39" 128GB - Twilight
£779.98
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Iconic design
  • Natural masterpiece
  • Balance in art
  • Precise GPS
  • Massive battery capacity
  • Triple camera
  • Capture the night
  • Operating system: Android
  • Model: Mate 20 Pro
  • Screen Size: 6.39in
  • Rear Camera: 40 Megapixel
  • Mobile Connectivity: 4G
Product codes
Limitless human imagination—that’s the inspiration for the HUAWEI Mate 20 Pro. The breakthroughs in technology will blur the lines between what you can dream and what you can do.
Natural Masterpiece
A forged masterpiece of 3D glass with smooth curves and seams that dissolve into the design. A streamlined symphony in the palm of your hand.
Balance in Art
Like all works of art, HUAWEI Mate 20 Pro’s lines and features are symmetrically in harmony. A slim design makes the phone size a pleasure to look at and touch.
The World is Your Playground
Life is about exploring. Take your HUAWEI Mate 20 Pro for fun to the beach or through the rain. The IP68 rated water and dust resistance means no worry of taking spills, splashes, and dunks.
World’s 1st 7nm Mobile AI Chipset
The industry-leading 7nm process technology of Kirin 980 generates direct performance upgrade of speed improvement and power efficiency.
Ultimate Speed
HUAWEI Mate 20 Pro is the World’s first 1.4 Gbps LTE Cat.21 smartphone which supports up to 1733 Mbps WiFi download speeds. Enjoy rapid, seamless connectivity anytime, anywhere.
Precise GPS
By leveraging L1&L5 dual frequency simultaneously, HUAWEI Mate 20 Pro allows you to always find the destination with great accuracy even in city centres surrounded by skyscrapers or highway interchanges.
Massive Capacity
Enduring power is always the symbol of the Mate series. A larger 4200 mAh battery with smarter AI power management fuels your daily work and entertainment needs.
New Leica Triple Camera
The new Leica Triple Camera powered by AI reveals life’s drama, texture, colour and beauty in every photograph that will take your breath away.
Designed for different scenarios, the 40 MP main RGB lens captures great details in everyday photos, while the 8 MP telephoto lens will focus on your distant shots and the whole new 20 MP Leica Ultra Wide Angle Lens is perfect for the landscape photos and macro shots.
Get Closer
Capture details and surprises you couldn’t before. The Leica Ultra Wide Angle Lens takes extreme close-up shots from 2.5 cm. Discover the world from a new perspective.
AI-Painting Photography
recognising more than 1500 scenarios and 25 categories, the upgraded AI-powered photography now can segment different objects and scenes in one photo. Colours, brightness and contrast are adjusted automatically and precisely, just like fine-painting a photo, with perfect balance.
Capture the Night
Powered by advanced AI Image Stabilisation, the Night mode will shoot blur-free and focused handheld photos in low-light. It also balances high-contrast scenes to present incredible images in every setting.
3D Face Unlock
A leap in accuracy and security. Thanks to the 3D Depth Sensing Camera projecting over 30000 points, HUAWEI Mate 20 Pro recognises you easily to unlock your phone swiftly. Your face ID can also be used to securely access a private screen containing locked APPs and personal data.
In-screen Fingerprint
With the ergonomic design and Dynamic Pressure Sensing technology, you just need to raise your finger and touch the screen, your phone will get unlocked securely and instantly.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
Product Description Huawei Mate 20 Pro - Twilight - 4G - 128 GB - GSM - smartphone
Product Type Smartphone 4G
Display OLED display - 3120 x 1440 pixels - 6.39" - 538 ppi
Features Front-facing camera, digital player, triple rear-facing camera
Processor Hisilicon Kirin 980 2.6 GHz (8-core) - 64-bit
Memory 128 GB - RAM 6 GB + NM card slot - up to 256 GB
Operating System Android 9.0 Pie with HUAWEI Emotion UI 9.0
Rear Camera 40 Megapixel - wide-angle lens - f/1.8 - focus: automatic
Second Rear Camera 20 Megapixel - ultra wide-angle lens - f/2.2
Third Rear Camera 8 Megapixel - telephoto lens - f/2.4
Front Camera 24 Megapixel f/2.0 - automatic
Service Provider Not specified
SIM Card Type Nano SIM
SIM Card Slot Qty Single-SIM
Wireless Interface NFC, Wi-Fi, Bluetooth
Security Devices Fingerprint reader, 3D Face unlock
Messaging Services SMS, MMS
Connectors USB-C
Wireless Charging Standards Qi
Protection Dustproof, splashproof, waterproof
Colour Twilight
Dimensions (WxDxH) 72.3 mm x 8.6 mm x 157.8 mm
Weight 189 g
SAR 0.96 W/kg (body) / 0.4 W/kg (head) - Category C (Belgium)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Huawei Mate 20 Pro 6.3...
£779.98
