Huawei MediaPad T3 10" Lite 16GB LTE - Space Grey
£148.51
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered on Wednesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Clarity with vision
  • Joy, that lasts
  • Powerful by nature, friendly by design
  • Take your family along
  • Operating System: Android 7.0 (Nougat)
  • Processor: Octa Core 1.4GHz Processor
  • Screen Size: 9.6in
  • RAM: 2GB
  • Capacity: 16GB
Product codes
Touch the power of brilliant design with your HUAWEI MediaPad T3 10. See the world in vibrant colour through the vivid 9.6 inch display. Feel the quality in the single-piece space-age anodized aluminum body. The HUAWEI MediaPad T3 10 is there for you, day or night. The special low-light and eye protection mode makes sure that you keep the full view of your life, reducing eye strain and helping preserve your natural sleep pattern. Stand out, get out, the HUAWEI MediaPad T3 10 is your loyal companion, day or night. The long-lasting battery will make sure that you have the tools you need, for as long as you need them. Always feel like you're with a trusted friend, with the HUAWEI MediaPad T3 10 EMUI 5.1 operation system, carefully designed for intuitive, easy interaction. Powered by android 7.0, the custom OS of the HUAWEI MediaPad T3 10 is here to make your life easier. Smart app access and content control allows you to let others use your device in a way that gives you full control. Whether letting children play, sharing the device, or even keeping yourself from getting distracted, you are the master.
  • Octa Core 1.4GHz Processor
  • 9.6" Capacitive Screen
  • 1280 x 800 Resolution
  • 16GB Storage
  • Android 7.0 Operating System
Product Description HUAWEI MediaPad T3 10 - tablet - Android 7.0 (Nougat) - 16 GB - 9.6" - 4G
Product Type Tablet
Operating System Android 7.0 (Nougat)
Display 9.6" IPS TFT - 1280 x 800 - Multi-Touch
Processor Qualcomm MSM8917 (Quad-Core)
Processor Clock Speed 1.4 GHz
Storage 16 GB
RAM 2 GB
Supported Flash Memory Cards microSD
Cellular Technology 4G
Cellular Protocols GSM, UMTS, TD-SCDMA, LTE, FDD LTE, TDD LTE
Wireless Connectivity 802.11a/b/g/n, Bluetooth 4.1
Camera 5 Megapixel (rear), 2 Megapixel (front)
Navigation System GPS/GLONASS/BeiDou
Features USB host
Dimensions (WxDxH) 22.98 cm x 0.795 cm x 15.98 cm
Weight 460 g
Colour Grey
Localisation United Kingdom
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Huawei MediaPad T3 10"...
£148.51
