Huawei MediaPad T3 8" WiFi Space Gray
FREE DELIVERY
LIMITED TIME OFFER
WAS £119.99!
£79.99
More than 50 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Strength of design in an elegant package
  • Sleek solid style
  • Joy, that lasts
  • Take your family along
  • Operating System: Android 7.0 (Nougat)
  • Processor: MSM8917
  • Screen Size: 8in
  • RAM: 2GB
  • Stock Status: Clearance, Used Stock
Product codes
Visuals with vision
See the world in crisp and vivid colour with the HUAWEI MediaPad T3 8-inch IPS HD Display. This high resolution display will bring your watching experience to next level while providing for comfort, for your grip, and for your eyes. The blue-light filter and low-light display modes make sure that you don’t tire your eyes.
Strong things can come in slim packages. HUAWEI MediaPad T3 delivers power and smooth usability while being only 7.95 mm thick and weighing in at just 350 grams. Housed in this elegant case is everything you need to enjoy a truly modern online experience.
Sleek, Solid Style
Made from a solid piece of sleek anodised aluminum, the feeling of this device exudes sleek strength and refined style. The sleek design and the raw power of this device are perfectly captured in the tastefully polished metallic finish.
Joy that lasts
HUAWEI MediaPad T3 delivers long-lasting enjoyment, even with heavy use. The 4800 mAh (TPY) battery keeps the lights on for longer, giving you an unrushed, uninterrupted experience.
Smart app access and content control allows you to let others use your device in a way that gives you full control. Whether letting children play, sharing the device, or even keeping yourself from getting distracted, you are the master.
Product Description HUAWEI MediaPad T3 - tablet - Android 7.0 (Nougat) - 16 GB - 8"
Product Type Tablet
Operating System Android 7.0 (Nougat)
Display 8" IPS - 1280 x 800
Processor Qualcomm MSM8917 (Quad-Core)
Processor Clock Speed 1.4 GHz
Storage 16 GB
RAM 2 GB
Supported Flash Memory Cards microSD, microSDHC, microSDXC
Wireless Connectivity 802.11a/b/g/n, Bluetooth 4.1
Camera 5 Megapixel (rear), 2 Megapixel (front)
HD Video Recording 1080p
Navigation System GPS/GLONASS/BeiDou
Features USB host
Dimensions (WxDxH) 12.47 cm x 0.8 cm x 21.11 cm
Weight 350 g
Colour Grey
Localisation United Kingdom
Environmental Standards ENERGY STAR Qualified
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: CZVJ 040952
£77.70
product
Ref: CZVJ 040952
Accessories
Packaging
Functional
Software
Manuals
£77.70
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Huawei MediaPad T3 8"...
£79.99
