HyperX Cloud II Gaming Headset PC/Mac/PS4/Xbox- Gun Metal
£91.89
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Advanced USB audio control box with built-in DSP sound card
  • 7.1 virtual surround sound
  • Digitally enhanced noise-canceling microphone
Product codes
Clarity never felt so comfortable.
HyperX® Cloud II features a redesigned USB sound card audio control box that ampli es audio and voice for an optimal Hi-Fi gaming experience, so you can hear what you've been missing. Open up a world of detail that other gamers will never know -- the rustle of a camper's boot, the scuttle in a distant vent. Its independent audio and microphone volume control lets you adjust not only sound volume but also mic volume and easily toggle Surround Sound 7.1 or the mic sound on and on .This next-generation headset generates virtual 7.1 surround sound with distance and depth to enhance your gaming, movie or music experience. Pinpoint your opponents' location in the game and strike before he sees you coming. It's hardware driven and plug and play, with no driver needed.
HyperX Cloud II has a digitally enhanced, noise-cancelling microphone with automatic gain control functionality and echo cancellation enabled through the USB sound card. The result is clearer voice quality and reduced background noise, with voice volume automatically increasing as in-game sound gets louder, to optimise team communication and in-game chat in intense battles. HyperX Cloud II is certified by TeamSpeak and optimised for Skype and other leading chat programs.
HyperX Cloud II is Hi-Fi capable, with 53mm drivers for superior audio performance and rich sound quality with crystal-clear low, mid and high tones and enhanced bass via the sound card.
Pro-gaming optimised, HyperX Cloud II is USB-powered for PCs and Macs and 3.5mm stereo-compatible for PS4 and Xbox One.1 Its closed-cup design helps with noise cancellation in gaming tournaments and other loud environments so players can obliterate the enemy in peace.
HyperX Cloud II comes in three new colours -- Gun Metal, Pink and Red -- and is covered by a two-year warranty and free technical support.
  • Digitally enhanced noise-cancelling microphone
  • Newly designed full USB audio control box
  • Premium sound card enables superior audio
  • 7.1 virtual surround sound control
  • Independent headset and microphone volume control
  • Microphone slide mute
  • Backlit LED
F E AT U R E S / B E N E F I T S
Audio experience -- hardware-driven virtual surround sound
Comfortable -- 100% memory foam on headband and leatherette cushions
Pro-gaming optimised -- closed-cup design for passive noise cancellation
Compatible -- USB connectivity for PC & Mac. Stereo compatible with PS4, Xbox One1 and mobile
Guaranteed -- two-year warranty, free technical support
S P E C I F I C AT I O N S
Headset:
Transducer type
: dynamic Ø 53mm with neodymium magnets
Operating principle: closed
Frequency response: 15Hz-25,000 Hz
Nominal impedance: 60 per system
Nominal SPL: 98±3dB
THD: < 2%
Power handling capacity: 150mW
Sound coupling to the ear: circumaural
Ambient noise attenuation: approx. 20 dBa
Headband pressure: 5N
Weight with microphone and cable: 320g
Cable length and type: 1m + 2m extension
Connection: single mini stereo jack plug (3.5 mm)
Microphone:
> Transducer type: condenser (back electret)
> Operating principle: pressure gradient
> Polar pattern: cardioid
> Power supply: AB powering
> Supply voltage: 2V
> Current consumption: max 0.5 mA
> Nominal impedance: 2.2 k
> Open circuit voltage: at f = 1 kHz: 20 mV / Pa
> Frequency response: 50-18,000 Hz
> THD: 2% at f = 1 kHz
> Max. SPL: 105dB SPL (THD1.0% at 1 KHz)
> Microphone output: -39±3dB
> Length mic boom: 150mm (include gooseneck)
> Capsule diameter: Ø6*5 mm
> Connection: single mini stereo jack plug (3.5mm)
Product Description HyperX Cloud II - headset
Product Type Headset - wired
Recommended Use Game console, portable electronics, computer
Colour Gun metal
Headphones Form Factor Full size
Connectivity Technology Wired
Headphones Technology Dynamic
Sound Output Mode Stereo
Sound Effects 7.1 Channel Virtual Surround Sound
Audio Specifications Frequency Response 15 - 25000 Hz - Sensitivity 98 dB
Impedance 60 Ohm
Microphone Detachable - boom
Microphone Technology Electret condenser
Controls Volume, microphone on/off, surround on/off
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HyperX Cloud II Gaming...
£91.89
