HyperX Cloud RevolverS headset
£168.20
Delivery:
Standard: 1-3 working days
Key features
  • Plug N Play surround 7.1 audio technology
  • Advanced USB audio control box with DSP sound card
  • Studio-grade sound stage lets you hear enemies before they hear you
  • Next-generation directional drivers pump out crisp, precise audio
  • Recommended Use: Computer, Game console, Portable electronics
  • Connectivity: Wired
  • Earcover : Binaural
Product codes
HyperX Cloud Revolver S is primed for action with Plug N Play surround 7.1 audio. Hear every footstep, explosion and gunshot with cinematic clarity as the simulated seven positional speakers provide precise sound with distance and depth. The advanced USB digital signal processing sound card handles everything, delivering consistent premium-quality sound, no matter what system you're playing on. Backlit buttons on the clippable audio control box allow you to quickly activate audio, mute and regulate mic and output levels. Bass boost and vocal equalizer modes let you swap between setups tuned for games, streaming, music or movies. Revolver S has a studio-grade sound stage that excels in FPS and open environment settings, letting you hear sounds further away more accurately.
The unique Revolver S driver design separates the lows, mids and highs and the re-engineered profiles produce sounds audiophiles will rave about. Serious gamers and streamers will love the higher-quality dense HyperX signature memory foam and the wider headband that reduces head pressure and more evenly distributes weight. Cloud Revolver S has a solid-steel frame for long-lasting durability and stability and is built to deliver sonic perfection for years. Closed ear cups block out outside noise to fully immerse you in Cloud's signature crisp, clear sound quality and enhanced bass.
Product Description HyperX Cloud Revolver S - headset
Product Type Headset - wired - USB, 3.5 mm jack
Compatibility Mac, Windows
Recommended Use Game console, portable electronics, computer
Localisation EMEA
Headphones Form Factor Full size
Connectivity Technology Wired
Headphones Technology Dynamic
Sound Output Mode Stereo
Sound Effects 7.1 Channel Virtual Surround Sound
Audio Specifications Frequency Response 12 - 28000 Hz - Sensitivity 100.5 dB/mW
Impedance 30 Ohm
Max Input Power 500 mW
Microphone Boom
Microphone Technology Electret condenser
Microphone Operation Mode Uni-directional
Controls Mute, volume
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HyperX Cloud RevolverS...
£168.20
