HyperX FURY Black 4GB DDR3L 1866MHz CL11 DIMM Memory
£19.93
Delivery:
Key features
  • Automatic overclocking up to 1866 MHz
  • Voltages start as low as 1,35V
  • Asymmetric, aggressive heat spreader design
Product codes
Auto-overclocking up to 1866 MHz to get you in the game faster.
HyperX FURY DDR3 memory automatically overclocks up to 1866 MHz for hassle-free, Plug and Play functionality that gets you in the game faster and instant top-level performance that helps you win it. With voltages as low as 1,35V, it draws less power and generates less heat, while supporting Intel's 100 Series chipset.
Its asymmetric, aggressive design lets you stand out from the crowd of "squared" designs and features quality aluminum and a diamond-cut finish.
Product Description HyperX FURY - DDR3L - 4 GB - DIMM 240-pin - unbuffered
Product Type RAM memory
Capacity 4 GB
Memory Type DDR3L SDRAM - DIMM 240-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 1866 MHz (PC3L-14900)
Latency Timings CL11 (11-11-11)
Features Single rank, black heatsink, eight banks, On-Die Termination (ODT), Low Voltage, Black PCB, FURY asymmetric heatspreader, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage 1.35 / 1.5 V
Manufacturer Warranty Limited lifetime warranty (Russia - 10 years)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HyperX FURY Black 4GB...
£19.93
