Get in the game with HyperX FURY. Even newbies get up to speed fast, since FURY automatically recognises its host platform and automatically overclocks to the highest frequency published - up to 1866MHz - providing plenty of power for your next deathmatch. Affordably priced, FURY's asymmetric heat spreader design is available in black, blue, red and- for the first time in the HyperX line -white, with a black PCB. It's 100 per cent tested and backed by a lifetime warranty and free technical support.
Features & Benefits
Product Description | HyperX FURY - DDR3 - 4 GB - DIMM 240-pin - unbuffered | Product Type | RAM memory | Capacity | 4 GB | Memory Type | DDR3 SDRAM - DIMM 240-pin | Upgrade Type | Generic | Data Integrity Check | Non-ECC | Speed | 1600 MHz (PC3-12800) | Latency Timings | CL10 (10-10-10-30) | Features | Black PCB, FURY asymmetric heatspreader, unbuffered | Voltage | 1.5 V | Lead Plating | Gold | Manufacturer Warranty | Limited lifetime warranty (Russia - 10 years) |
General | |
Capacity | 4 GB |
Memory | |
Type | DRAM |
Technology | DDR3 SDRAM |
Form Factor | DIMM 240-pin |
Module Height (inch) | 1.29 |
Module Configuration | 512 x 64 |
Voltage | 1.5 V |
Expansion / Connectivity | |
Compatible Slots | 1 x memory - DIMM 240-pin |
Miscellaneous | |
Colour Category | Black |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty (Russia - 10 years) |
