HyperX FURY Blue 4GB DDR3 1866MHz CL10 DIMM Memory
£19.93
Delivery:
Key features
  • Superior efficiency
  • Bold, asymmetric heat spreader
Product codes
Get in the game with HyperX FURY. Even newbies get up to speed fast, since FURY automatically recognises its host platform and automatically overclocks to the highest frequency published - up to 1866MHz - providing plenty of power for your next deathmatch. Affordably priced, FURY's asymmetric heat spreader design is available in black, blue, red and- for the first time in the HyperX line -white, with a black PCB. It's 100 per cent tested and backed by a lifetime warranty and free technical support.
  • Asymmetric heat spreader for stylish heat dissipation
  • Compatible with Intel and AMD platforms
Features & Benefits
  • Unique -- tested with all popular brands of motherboards
  • Easy to install -- Plug-and-Play functionality
  • Automatic overclocking -- reach faster speeds and higher capacities just by installing the memory, no adjustments in BIOS needed
  • Reliable -- 100 per cent factory tested
  • Lifetime warranty, free technical support
  • Capacity 4GB
  • Frequency speed 1866MHz
  • CAS latency 10-10-10-30
  • Voltage 1.5V
  • Operating temperature 0C to 85C
  • Storage temperature -55C to 100C
  • Dimensions 133.35mm x 32.8mm
  • Compatible with P55, H67, P67, Z68, Z77, Z87 and H61 Intel chipsets, as well as A75, A87, A88, A89, A78 and E35 AMD chipsets
Product Description HyperX FURY - DDR3 - 4 GB - DIMM 240-pin - unbuffered
Product Type RAM memory
Capacity 4 GB
Memory Type DDR3 SDRAM - DIMM 240-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 1866 MHz (PC3-14900)
Latency Timings CL10 (10-10-10-30)
Features Black PCB, FURY asymmetric heatspreader, unbuffered
Voltage 1.5 V
Lead Plating Gold
Manufacturer Warranty Limited lifetime warranty (Russia - 10 years)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HyperX FURY Blue 4GB D...
£19.93
