HyperX FURY Red 32GB (4x8GB) DDR4 2666MHz CL16 DIMM Memory
£190.04
Delivery:
Standard: 1-3 working days
Key features
  • Optimized for the chipsets - plug it in and you're good to game
  • Cost-efficient premium DDR4 upgrade, enhance performance without breaking the bank
  • Low power consumption - stays cooler and draws less power
  • Stylish, low-profile heat spreader in signature FURY asymmetrical design
  • Type: DDR4 SDRAM
  • Capacity: 32GB
  • Connection: DIMM 288-pin
  • Speed: 2666MHz
  • Data Integrity: Non-ECC
Product codes
HyperX® FURY DDR4 automatically recognises the platform it’s plugged into and automatically overclocks to the highest frequency published, up to 2666MHz, for hassle-free, plug-and-play functionality. It delivers automatic top-level performance for motherboards featuring Intel’s 200 series and X99 chipsets and complements Intel’s 2, 4, 6, 8 and 10-core processors for faster video editing, 3D rendering, gaming and AI processing. Available in speeds from 2133MHz–2666MHz, CL14–16 latencies and capacities of 4GB, 8GB and 16GB single modules and 8GB–64GB kits, HyperX FURY DDR4 is a minimal investment in premium components that results in faster speeds, higher performance and enhanced reliability – plus it looks really cool. It stays cool, too, thanks to 1.2V power consumption resulting in less heat, with a lower voltage specification than DDR3. Its stylish, low-profile design complements the look of the latest PC hardware while helping you stand out from the crowd of squared designs.
Product Description HyperX FURY - DDR4 - 32 GB 4 x 8 GB - DIMM 288-pin - unbuffered
Product Type RAM memory
Capacity 32 GB 4 x 8 GB
Memory Type DDR4 SDRAM - DIMM 288-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 2666 MHz (PC4-21300)
Latency Timings CL16 (16-18-18)
Features On-Die Termination (ODT), Serial Presence Detect (SPD), Black PCB, quad channel, low profile heatspreader, FURY asymmetric heatspreader, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage 1.2 V
Lead Plating Gold
Manufacturer Warranty Limited lifetime warranty (Russia - 10 years)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HyperX FURY Red 32GB (...
£190.04
