Kingston HyperX Impact - DDR4 - 16 GB: 2 x 8 GB - SO-DIMM 260-pin - 2400 MHz / PC4-19200 - CL14 - 1.2 V - unbuffered - non-ECC
Product Description | HyperX Impact - DDR4 - 16 GB: 2 x 8 GB - SO-DIMM 260-pin - unbuffered | Product Type | RAM memory | Capacity | 16 GB: 2 x 8 GB | Memory Type | DDR4 SDRAM - SO-DIMM 260-pin | Upgrade Type | Generic | Data Integrity Check | Non-ECC | Speed | 2400 MHz (PC4-19200) | Latency Timings | CL14 (14-14-14) | Features | On-Die Termination (ODT), Black PCB, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered | Voltage | 1.2 V | Manufacturer Warranty | Limited lifetime warranty (Russia - 10 years) |
General | |
Memory | |
Type | DRAM |
Technology | DDR4 SDRAM |
Form Factor | SO-DIMM 260-pin |
Module Height (inch) | 1.18 |
Module Configuration | 1024 x 64 |
Voltage | 1.2 V |
RAM Performance | SPD - 2133 MHz - 1.2 V - CL13 - 13-13-13 , Intel Extreme Memory Profiles (XMP 2.0) - 2400 MHz - 1.2 V - CL14 - 14-14-14 |
Miscellaneous | |
Colour Category | Black |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty (Russia - 10 years) |
