HyperX Impact Black 8GB (2x4GB) DDR4 2400MHz CL14 SODIMM Memory
£35.59
Delivery:
Key features
  • Fast performance for Intel's 100 series-based SO-DIMM systems
  • Automatic overclocking to the highest frequency published
  • At 1.2V, lower voltage than DDR3
  • Slim form and sleek design
Product codes
Powerful SO-DIMM performance optimized for Intel's 100 series chipset.
Make an Impact in your game with powerful HyperX Impact DDR4 SO-DIMM. It automatically overclocks to the highest frequency published, up to 2666 MHz, without the need to adjust system BIOS settings, to support platforms that use Intel's CPU technologies. You get instant top-level performance with lower voltage that helps your system run cooler, quieter and more efficiently. All you'll ever miss is lag time.
HyperX Impact DDR4 has a slim form for easy installation in slim or ultra-slim notebooks and features a sleek design with a matching PCB that adds an aggressive look.
Product Description HyperX Impact - DDR4 - 8 GB: 2 x 4 GB - SO-DIMM 260-pin - unbuffered
Product Type RAM memory
Capacity 8 GB: 2 x 4 GB
Memory Type DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 2400 MHz (PC4-19200)
Latency Timings CL14 (14-14-14)
Features Single rank, On-Die Termination (ODT), dual channel, Black PCB, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage 1.2 V
Manufacturer Warranty Limited lifetime warranty (Russia - 10 years)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HyperX Impact Black 8G...
£35.59
