The iiyama DS1002D-B1 is a desk stand for two flat screens up to 30". The device allows you to save space on your desk reducing the number of stands to one only and the cable management system makes it easier to keep your workplace tidy. The easy to set-up stand offers broad adjustment capabilities, including tilt, swivel, height and rotation, so you can easily adjust the position of both screens to your preferences assuring comfortable and healthy body posture.
Product Description | Iiyama DS1002D-B1 - stand - adjustable arm - for 2 monitors - black | Product Type | Stand (adjustable arm) - desktop stand | Tilt | -85° to 15° | Pan | 180° | Lift | 14 cm | Rotation | 90° | Recommended Use | 2 monitors | Recommended Display Size | 10"-30" | VESA Mounting Interface | 100 x 100 mm, 75 x 75 mm | Max Load Weight | 10 kg | Colour | Black | Manufacturer Warranty | 5-year warranty | Designed For | ProLite E2783QSU-B1, XU2495WSU-B1, XUB2495WSU-B1 |
General | |
Colour | Black |
AV Furniture | |
Type | Stand |
Design | Adjustable arm |
Placing / Mounting | Desktop stand |
Cable Management | Integrated cable management |
Pan | 180° |
Lift | 14 cm |
Rotation | 90° |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Compatibility Information | |
Designed For | Iiyama ProLite E2783QSU-B1, XU2495WSU-B1, XUB2495WSU-B1 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
