iiyama E2482HD-B1 23.6" 1920x1080 5ms VGA DVI-D LED Monitor
Product codes
The ProLite E2482HD is an excellent 24" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 5 ms response time and advanced contrast ratio, assuring clear and vibrant picture quality and high contrast. The E2482HD is also Energy Star certified. This monitor is a reliable solution for both home and office use.
Product Description iiyama ProLite E2482HD - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class B
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.277 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 12000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Display Position Adjustments Tilt
Colour Black
Dimensions (WxDxH) 56.55 cm x 20.3 cm x 41.2 cm
Weight 3.3 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, TUV GS, DDC-2B, VESA DPMS, VCCI Class B
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama E2482HD-B1 23.6...
