We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
With IPS panel, 144Hz refresh rate, 1ms MPRT and the 3440x1440 resolution, the monitor allows hardcore gamers to unleash their gaming potential and enjoy superb image quality. The height adjustable stand ensures you can easily adjust the screen position to your preferences and the ability to customize the screen settings using the predefined and custom gaming modes along with the Black Tuner function gives you control over the dark scenes to make sure details are always clearly visible.
Product Description | iiyama G-MASTER Red Eagle GB3461WQSU-B1 - LED monitor - 34" | Device Type | LED-backlit LCD monitor - 34" | Energy Class | Class G | Energy Consumption per Year | 69 kWh | Power Consumption (On mode) | 39.6 W | Adaptive-Sync Technology | AMD FreeSync Premium | Features | USB 3.0 hub | Panel Type | ADS-IPS | Aspect Ratio | 21:9 | Native Resolution | UWQHD 3440 x 1440 (DisplayPort: 144 Hz, HDMI: 120 Hz) | Pixel Pitch | 0.233 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 / 80000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey), 1 ms (MPRT) | Colour Support | 16.7 million colours | Colour Gamut | 100% sRGB, 74% NTSC | Input Connectors | 2xHDMI, 2xDisplayPort | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Matte | Voltage | AC 120/230 V (50/60 Hz) | Colour | Matte black | Dimensions (WxDxH) - with stand | 81.7 cm x 23 cm x 41.5 cm | Weight | 9.7 kg | Compliant Standards | VCCI, DDC-2B, RoHS, WEEE, PSE Mark, TUV Bauart, EAC, REACH SvHC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 34" |
Built-in Devices | USB 3.0 hub |
Vertical Refresh Rate | 15 - 144 Hz |
Horizontal Refresh Rate | 30 - 220 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
OSD Languages | Czech, English, German, French, Italian, Polish, Russian, Dutch, Japanese |
Features | Picture in picture, picture by picture, HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), X-Res Technology, Flicker Free technology, i-Style Color, Black Tuner, HDR Ready technology, Blue Light Reducer Function |
Dimensions (WxDxH) | 81.7 cm x 23 cm x 41.5 cm - with stand |
Weight | 9.7 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 5 Watt |
Connectivity | |
Interfaces | 2 x HDMI , 2 x DisplayPort , 2 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Headphones (mini-jack) |
Mechanical | |
Tilt Angle | -3/+22 |
Swivel Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x USB cable , 1 x HDMI cable , 1 x DisplayPort cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 39.6 kWh/1000h |
Power Consumption HDR (On mode) | 55.5 kWh/1000h |
Power Consumption (Typical) | 49 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 81.7 cm - depth: 5.85 cm - height: 36.7 cm , With stand - width: 81.7 cm - depth: 23 cm - height: 41.5 cm - weight: 9.7 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 90 cm |
Shipping Depth | 23 cm |
Shipping Height | 46 cm |
Shipping Weight | 12.8 kg |
Manufacturer Warranty | |
Service & Support | 3-year warranty |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
