iiyama G-Master G2730HSU-B1 27" 1ms 1920x1080 VGA HDMI M...
iiyama G-Master G2730HSU-B1 27" 1ms 1920x1080 VGA HDMI Monitor
£160.87
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Black Tuner
  • Predefined and custom gaming modes
  • Diagonal Size: 27in
  • Max Resolution: 1920 x 1080
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
G-MASTER G2730HSU-B1 Black Hawk – get in the game No matter if you are a newbie or an old wolf in the world of gaming, the 27’’ Black Hawk G-MASTER G2730HSU is the perfect companion at your side. Capable of displaying Full HD images at 75Hz refresh rate it will always have your back. Armed with Black Tuner function and FreeSync Technology with a stunning 1 ms response time, the Black Hawk guarantees you will see every tiny detail even in the shadowed screen areas and will be able to respond to the changing situation in an instant. Triple input support (VGA, HDMI, DisplayPort), speakers, headphone connector and a USB hub are all included. So stay in control, keep calm and get in the game! If 27'' is too big for you, check out the 24.5'' Black Hawk G2530HSU.
Product Description iiyama G-MASTER Black Hawk G2730HSU-B1 - LED monitor - Full HD (1080p) - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A+
Energy Consumption per Year 29 kWh
Power Consumption (On mode) 19.7 W
Adaptive-Sync Technology AMD FreeSync
Features USB 2.0 hub
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch 0.311 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 12000000:1 (dynamic)
Response Time 1 ms
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Matte
Colour Black
Dimensions (WxDxH) 61.35 cm x 19.7 cm x 44.05 cm
Weight 5.3 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, TUV GS, DDC-2B, DVI DMPM, VESA DPMS, CU, VESA DDC 2 B
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama G-Master G2730H...
£160.87
