iiyama G-Master GB2488HSU-B2 24" 1920x1080 VGA DVI HDMI...
iiyama G-Master GB2488HSU-B2 24" 1920x1080 VGA DVI HDMI DP 1ms Monitor
£289.27
Delivery:
Key features
  • FreeSync technology
  • Black Tuner
  • OverDrive On/Off
  • When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that
  • Speakers and headphones
Product codes
The 27" G-MASTER GB2788HS known as Red Eagle is a real game changer, giving true gamers the competitive edge they need to make split second decisions. It spikes down on your enemies with a blistering 1 ms response time, ensuring fluid and accurate transition between the images.
Armed with FreeSync technology and 144Hz refresh rate, this powerful predator has no mercy for ghosting effects or smearing issues. Perfect vision manifested in the ability to adjust brightness and the dark shades with the Black Tuner delivers greater viewing performance in shadowed areas. No matter which you prefer: RTS, FPS, MOBA and MMO - choose Red Eagle and rank yourself top of the gamer community food chain.
iiyama G-MASTER Red Eagle - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
35.3 W
Adaptive-Sync Technology
AMD FreeSync
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.277 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, DisplayPort
Display Position Adjustments
56.8 cm x 23 cm x 38.5 cm
5.6 kg
DDC-2B, PSE Mark, TUV Bauart, VCCI Class B
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama G-Master GB2488...
£289.27
