iiyama G-Master GB2760QSU-B1 27" 2560x1440 1ms VGA HDMI...
£328.77
22 in stock
Delivery:
Standard: 1-3 working days
Key features
  • FreeSync technology
  • Predefined and custom gaming modes
  • Diagonal Size: 27in
  • Max Resolution: 2560 x 1440
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI
Product codes
G-MASTER GB2760QSU-B1 Red Eagle – join the PRO squad Whether you already are or are aiming to be a hardcore gamer, the 27’’ G-MASTER GB2760QSU known as Red Eagle is the competitive edge you need to be able to unleash your full gaming potential. Armed with FreeSync technology, 144Hz refresh rate and a blistering 1ms response time you can make split second decisions and forget about ghosting effects or smearing issues. The WQHD (2560x1440) display offers 77% more on-screen space than a standard 1920x1080 full HD monitor. The ability to adjust brightness and the dark shades with the Black Tuner delivers greater viewing performance in shadowed areas. Nothing will skip your attention. Triple input setup (DVI, HDMI, DisplayPort), speakers, headphone connector and a 3.0 USB hub are all included. So no matter which you prefer: RTS, FPS, MOBA and MMO – with the Red Eagle on your desk you are top of the gamer community food chain.
Product Description iiyama G-MASTER Red Eagle GB2760QSU-B1 - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class B
Energy Consumption per Year 59 kWh
Power Consumption (On mode) 40.5 W
Adaptive-Sync Technology AMD FreeSync
Features USB 3.0 hub
Panel Type TN
Aspect Ratio 16:9
Native Resolution WQHD 2560 x 1440 at 144 Hz
Pixel Pitch 0.233 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 12000000:1 (dynamic)
Response Time 1 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Matte
Colour Black
Dimensions (WxDxH) 61.35 cm x 23 cm x 39.75 cm
Weight 6.4 kg
Compliant Standards Plug and Play, TUV GS, DDC-2B, DVI DMPM, VESA DPMS, CU, VESA DDC 2 B
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama G-Master GB2760...
£328.77
