The iiyama DS3001C-B1 is a desk mount (grommet or clamp) for flat screens up to 27". Using the arm guarantees you gain additional space on your desk and the cable management system helps to keep the workplace tidy. But more importantly, offering broad adjustment capabilities including tilt, swivel, height and rotation, the arm makes sure you can easily adjust the screen position to your preferences assuring ergonomic body posture.
Product Description | Iiyama DS3001C-B1 - mounting kit - adjustable arm - for Monitor - black | Product Type | Mounting kit (adjustable arm) - desk-mountable | Tilt | -85° to 15° | Pan | 360° | Rotation | 90° | Recommended Use | Monitor | Recommended Display Size | 10"-27" | VESA Mounting Interface | 100 x 100 mm, 75 x 75 mm | Max Load Weight | 5 kg | Colour | Black | Manufacturer Warranty | 5-year warranty | Designed For | ProLite E2783QSU-B1, XU2495WSU-B1 |
General | |
Colour | Black |
AV Furniture | |
Type | Mounting kit |
Design | Adjustable arm |
Placing / Mounting | Desk-mountable |
Cable Management | Integrated cable management |
Pan | 360° |
Rotation | 90° |
Min Load Weight | 1.5 kg |
Details | Gas spring lift |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Compatibility Information | |
Designed For | Iiyama ProLite E2783QSU-B1, XU2495WSU-B1 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
