iiyama Gas Spring Mounting Arm Dual
£123.02
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
The iiyama DS3002C-B1 is a desk mount (grommet or clamp) for two flat screens up to 27". Using the arm you save space on your desk and thanks to the cable management system it is easier to keep your workplace tidy. But what is more important, offering broad adjustment capabilities including tilt, swivel, height and rotation, the dual gas spring arm makes sure you can easily adjust the position of the screens to your preferences assuring ergonomic body posture.
Product Description Iiyama DS3002C-B1 - desk mount (adjustable arm)
Product Type Desk mount (adjustable arm)
Tilt -85° to 15°
Pan 360°
Rotation 90°
Recommended Use 2 monitors
Recommended Display Size 10"-27"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 5 kg
Colour Black
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama Gas Spring Moun...
£123.02
