The iiyama DS3002C-B1 is a desk mount (grommet or clamp) for two flat screens up to 27". Using the arm you save space on your desk and thanks to the cable management system it is easier to keep your workplace tidy. But what is more important, offering broad adjustment capabilities including tilt, swivel, height and rotation, the dual gas spring arm makes sure you can easily adjust the position of the screens to your preferences assuring ergonomic body posture.
Product Description | Iiyama DS3002C-B1 - mounting kit - adjustable arm - for 2 monitors - black | Product Type | Mounting kit (adjustable arm) - desk-mountable | Tilt | -85° to 15° | Pan | 360° | Rotation | 90° | Recommended Use | 2 monitors | Recommended Display Size | 10"-27" | VESA Mounting Interface | 100 x 100 mm, 75 x 75 mm | Max Load Weight | 5 kg | Colour | Black | Manufacturer Warranty | 5-year warranty |
General | |
Colour | Black |
AV Furniture | |
Type | Mounting kit |
Design | Adjustable arm |
Placing / Mounting | Desk-mountable |
Cable Management | Integrated cable management |
Pan | 360° |
Rotation | 90° |
Min Load Weight | 1.5 kg |
Details | Gas spring lift |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
