iiyama GB2783QSU-B1 27" 2560 x 1440 1ms HDMI DVI DP Gami...
Product codes
The 27" G-MASTER GB2783QSU opens you to a whole different level of gaming experiences. The Silver Crow makes sure all the finest details are displayed with perfect image clarity. Nothing will skip your attention. The blue light reducer function along with the flicker-free panel are the shield your eyes need to guarantee your vision remains well protected. Armed with FreeSync technology and 1 ms response time the Silver Crow is ready to lead you into the toughest battles, leaving nothing to chance - the faith of your gaming destiny rests in your hands alone.
Product Description iiyama G-MASTER Silver Crow GB2783QSU-B1 - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class B
Energy Consumption per Year 62 kWh
Power Consumption (On mode) 42.6 W
Adaptive-Sync Technology AMD FreeSync
Features USB 3.0 hub
Panel Type TN
Aspect Ratio 16:9
Native Resolution 2560 x 1440
Pixel Pitch 0.233 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 12000000:1 (dynamic)
Response Time 1 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, DisplayPort
Display Position Adjustments Height, swivel, tilt
Colour Black
Dimensions (WxDxH) 62.25 cm x 23 cm x 40.05 cm
Weight 6.1 kg
Compliant Standards TUV GS, DDC-2B, VESA DPMS, DDC/CI, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama GB2783QSU-B1 27...
