We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
MD BRPCV01 is a high quality bracket that allows a Mini PC or Thin Client to be mounted to the iiyama Height Adjustable stand. This solution is compatible with almost all ThinClient/ZeroClient PC's and with basically all iiyama 19'' to 24'' height adjustable monitors.
Product Description | Iiyama thin client to monitor mounting bracket | Product Type | Thin client to monitor mounting bracket | Colour | White | Designed For | ProLite B1980SD-B1, B1980SD-W1, B2280HS-1, B2280HS-B1DP, B2280WSD-1, B2480HS, B2480HS-2, B2480HS-W1, B2481HS-1, XB2380HS, XB2485WSU, XB2485WSU-1, XB2485WSU-2 |
General | |
Colour | White |
Compatibility Information | |
Designed For | Iiyama ProLite B1980SD-B1, B1980SD-W1, B2280HS-1, B2280HS-B1DP, B2280WSD-1, B2480HS, B2480HS-2, B2480HS-W1, B2481HS-1, XB2380HS, XB2485WSU, XB2485WSU-1, XB2485WSU-2 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
