Iiyama P1905S-B2 19" 1280x1024 5ms VGA DVI-D LED Monitor
£163.68
12 left in stock
Delivery:
Standard: 1-3 working days
Key features
  • Protective glass
  • LED-backlit
  • Equipped with two high quality stereo speakers
  • Key lock
Product codes
The ProLite P1905S meets the increasing demands for protected LCDs within education, retail and industrial applications. In addition to having toughened safety glass fitted behind the bezel at 8H hardness rating capable of resisting above normal impacts to the display, Iiyama have enhanced the range to include the latest high performance and energy saving technology. Features include 5 ms response time, 1000:1 contrast ratio enhancing color and analog and DVI inputs. The displays are ENERGY STAR rated and have 19 W typical power consumption in use and less than 1 W in standby.
Product Description iiyama ProLite P1905S-2 - LED monitor - 19"
Device Type LED-backlit LCD monitor - 19"
Panel Type TN
Aspect Ratio 5:4
Native Resolution 1280 x 1024
Pixel Pitch 0.294 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Speakers Integrated
Display Position Adjustments Tilt
Screen Coating 8H Hard Coating
Colour Black
Dimensions (WxDxH) 41.45 cm x 20.05 cm x 42.05 cm
Weight 4.6 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, VESA DPMS
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Iiyama P1905S-B2 19" 1...
£163.68
