iiyama ProLite 24" 1920x1080 4ms HDMI DVI-D VGA LED Monitor
£122.11
Delivery:
Standard: 1-3 working days
Key features
  • Flicker-free and blue light
  • AMVA
  • OverDrive on/off
  • ACR
  • Full HD
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £125.60
Save £1.50
ProLite X2483HSU-B3 - a 24" LED backlit LCD Screen featuring AMVA panel technology, guarantees accurate and consistent colour reproduction with wide viewing angles. Offering 24 bit ‘True Colour’ and great performance for displaying Black and White with the 3000:1 Native Contrast Ratio, means that the Prolite X2483HSU-B3 will provide excellent performance for Photographic, Design and Web-design. With the added support of a Low Power LED Panel, the iiyama Prolite X2483HSU-B3 is an excellent choice for Universities, Corporate and Financial Markets.
Product Description iiyama ProLite X2483HSU-B3 - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class B
Features USB 2.0 hub
Panel Type A-MVA
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch 0.275 mm
Brightness 250 cd/m²
Contrast Ratio 3000:1 / 80000000:1 (dynamic)
Response Time 4 ms
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Matte
Colour Black
Dimensions (WxDxH) 55.25 cm x 20.3 cm x 40.65 cm
Weight 3.9 kg
Environmental Standards TCO Certified Displays 8, ENERGY STAR Qualified
Compliant Standards TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite 24" 192...
£122.11
