Iiyama Prolite 27" 2560x1440 Height Adjustable AH-IPS LC...
Iiyama Prolite 27" 2560x1440 Height Adjustable AH-IPS LCD Monitor
Key features
  • High definition images
  • Consistent color reproduction with wide viewing angles and high contrast
  • Smooth playback while watching films and playing games
  • Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment
  • Advanced Contrast Ratio automatically adjusts contrast and brightness of the screen to assure perfect picture quality
  • High-Definition Multimedia Interface supports audio as well as video signals
  • A height adjustable stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort
Product codes
The XB2779QS can display almost 77% more information on the screen than a Full HD display. Users can create their own workspace by displaying and manipulating multiple applications at the same time. The AH-IPS matrix guarantees high performance with accurate and consistent color reproduction, wide viewing angles and a fast response time. The XB2779QS is perfect for demanding users who settle only for the best specifications and modern design.
Product Description iiyama ProLite XB2779QS-1 - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class D
Energy Consumption per Year 98 kWh
Power Consumption (On mode) 67.3 W
Panel Type AH-IPS
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440
Pixel Pitch 0.233 mm
Brightness 440 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.8 million colours
Input Connectors HDMI, DVI-D, VGA, DisplayPort
Speakers Integrated
Display Position Adjustments Height, swivel, tilt
Colour Silver black
Dimensions (WxDxH) - with stand 65 cm x 23 cm x 43.55 cm
Weight 8.2 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards VESA DPMS, PSE Mark, GOST-R, TUV Bauart, VCCI Class B
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Iiyama Prolite 27" 256...
