iiyama Prolite 32" 2560x1440 4ms HDMI DVI DisplayPort LE...
iiyama Prolite 32" 2560x1440 4ms HDMI DVI DisplayPort LED Monitor
£252.62
Delivery:
Standard: 1-3 working days
Key features
  • IPS technology
  • Height adjustable stand
  • Flicker free + blue light
  • Speakers and headphones
  • Diagonal Size: 32in
  • Max Resolution: 2560 x 1440
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI
Product codes
Looking for the perfect monitor? Choose the all-around IPS panel technology guaranteeing perfect color reproduction with wide viewing angles. Meeting the demands of both graphic design and the modern work place, the XB3270QS with a high resolution offers the perfect solution for productivity, design and data analysis. The height-adjustable stand ensures you can adjust the screen position to your preferences, and the flicker-free panel with blue light reducer function reduces eye fatigue.
Product Description iiyama ProLite XB3270QS-B1 - LED monitor - 32"
Device Type LED-backlit LCD monitor - 32"
Energy Class Class C
Energy Consumption per Year 93 kWh
Power Consumption (On mode) 63.5 W
Panel Type IPS
Aspect Ratio 16:9
Native Resolution WQHD 2560 x 1440
Pixel Pitch 0.273 mm
Brightness 300 cd/m²
Contrast Ratio 1200:1 / 80000000:1 (dynamic)
Response Time 4 ms
Colour Support 1.07 billion colours
Input Connectors HDMI, DVI, DisplayPort
Display Position Adjustments Height, swivel, tilt
Colour Black
Dimensions (WxDxH) 73 cm x 23 cm x 44.45 cm
Weight 8.9 kg
Compliant Standards DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama Prolite 32" 256...
£252.62
