iiyama ProLite B1780SD-W1 17" 1280x1024 5ms VGA DVI-D LE...
iiyama ProLite B1780SD-W1 17" 1280x1024 5ms VGA DVI-D LED Monitor
£126.31
Delivery:
Standard: 1-3 working days
Key features
  • A height adjustable stand
  • LED-backlight
  • Advanced contrast ratio
  • Screen rotation
  • High quality stereo speakers
  • VESA mount compliance
  • Diagonal Size: 17in
  • Max Resolution: 1280 x 1024
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £129.80
Save £1.50
The 17" ProLite B1780SD designed for business usage is a LED-backlit monitor with height adjustability and screen rotation allowing you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort. The 5 ms response time and high contrast make the B1780SD ideal for a wide range of business applications. sRGB and gamma correction functions permit even the finest nuances of color to be set accurately. The ProLite B1780SD includes DVI and VGA connectivity.
Product Description iiyama ProLite B1780SD-1 - LED monitor - 17"
Device Type LED-backlit LCD monitor - 17"
Panel Type TN
Aspect Ratio 5:4
Native Resolution 1280 x 1024 at 75 Hz
Pixel Pitch 0.264 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Speakers Integrated
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour White
Dimensions (WxDxH) 37 cm x 23 cm x 39.95 cm
Weight 4.4 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards VESA DPMS, GOST-R, TUV Bauart, VCCI Class B
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite B1780SD...
£126.31
