iiyama ProLite B1980SD-B1 19" 1280x1024 5ms LED LCD DVI-...
iiyama ProLite B1980SD-B1 19" 1280x1024 5ms LED LCD DVI-D VGA Black Monitor with Speakers
£133.33
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Height Adjustable Stand
  • LED-backlit
  • Advanced Contrast Ratio
  • High quality stereo speaker
  • Diagonal Size: 19in
  • Max Resolution: 1280 x 1024
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £136.82
Save £1.50
The 19" ProLite B1980SD designed for business usage is a LED-backlit monitor with height adjustability and screen rotation allowing you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort. The 5 ms response time and high contrast make the B1980SD ideal for a wide range of business applications. sRGB and gamma correction functions permit even the finest nuances of color to be set accurately.
Product Description iiyama ProLite B1980SD-B1 - LED monitor - 19"
Device Type LED-backlit LCD monitor - 19"
Panel Type TN
Aspect Ratio 5:4
Native Resolution 1280 x 1024
Pixel Pitch 0.294 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Speakers Integrated
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) 41.1 cm x 24.45 cm x 42.65 cm
Weight 5.1 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, VESA DPMS, VCCI Class B
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite B1980SD...
£133.33
