iiyama ProLite B1980SD-W1 19" 1280x1024 5ms Height Adjus...
iiyama ProLite B1980SD-W1 19" 1280x1024 5ms Height Adjustable DVI-D VGA White Monitor with Speakers
£138.27
Delivery:
Standard: 1-3 working days
Key features
  • Height Adjustable Stand
  • LED-backlit
  • Advanced Contrast Ratio
  • Screen rotation
  • High quality stereo speaker
Product codes
The 19" ProLite B1980SD designed for business usage is a LED-backlit monitor with height adjustability and screen rotation allowing you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort. The 5 ms response time and high contrast make the B1980SD ideal for a wide range of business applications. sRGB and gamma correction functions permit even the finest nuances of color to be set accurately.
iiyama ProLite B1980SD-W1 - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
White
41.1 cm x 24.45 cm x 42.65 cm
5.1 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, VESA DPMS, TCO Certified Edge, TCO Displays 6.0, VCCI Class B
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite B1980SD...
£138.27
