iiyama ProLite B2280HS 22" 1920x1080 5ms HDMI DVI-D VGA...
iiyama ProLite B2280HS 22" 1920x1080 5ms HDMI DVI-D VGA White LED Monitor with Speakers
£98.77
42 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Excellent speakers
  • ACR
  • Full HD
  • Diagonal Size: 22in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, HDMI, VGA (HD-15)
Product codes
The ProLite B2280HS is a high specification 21.5" Full HD 1920 x 1080p LED-backlit monitor with Height Adjustability and Screen Rotation allowing you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort. 5msec black-to-black response time and 5 000 000:1 Advanced Contrast Ratio make the B2280HS ideal for Video Conferencing, DTP and CAD as well as the usual text based applications. Triple Input support of Analog, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded Notebook outputs. The monitor is Energy Star Certified.
Product Description iiyama ProLite B2280HS-1 - LED monitor - Full HD (1080p) - 22"
Device Type LED-backlit LCD monitor - 22"
Energy Class Class B
Energy Consumption per Year 35 kWh
Power Consumption (On mode) 23.8 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.2482 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA
Speakers Integrated
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour White
Dimensions (WxDxH) 50.95 cm x 24.45 cm x 39.3 cm
Weight 5.1 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, TUV GS, DDC-2B, VESA DPMS, TCO Displays 5.0
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite B2280HS...
£98.77
