iiyama ProLite B2280WSD-B 22" 1680x1050 5ms VGA DVI-D LE...
iiyama ProLite B2280WSD-B 22" 1680x1050 5ms VGA DVI-D LED Black Monitor with Speakers
£140.32
Delivery:
Standard: 1-3 working days
Key features
  • LED-backlight
  • Height adjustable stand
  • Diagonal Size: 22in
  • Max Resolution: 1680 x 1050
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £143.81
Save £1.50
The ProLite B2280WSD is a high specification 22" 1680 x 1050 LED-backlight monitor with height adjustability and screen rotation allowing you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort. 5 millisecond black-to-black response time and 5000000:1 advanced contrast ratio make the B22080WSD ideal for video conferencing, DTP and CAD as well as the usual text based applications. Analog and DVI inputs ensure compatibility with the systems and associated graphics cards.
Product Description iiyama ProLite B2280WSD-1 - LED monitor - 22"
Device Type LED-backlit LCD monitor - 22"
Panel Type TN
Aspect Ratio 16:10
Native Resolution 1680 x 1050 at 60 Hz
Pixel Pitch 0.282 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Speakers Integrated
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) 51.25 cm x 24.45 cm x 42.35 cm
Weight 5.5 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, VESA DPMS
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite B2280WS...
£140.32
