iiyama ProLite B2480HS-W2 22" 1920x1080 2MS VGA DVI-D HD...
iiyama ProLite B2480HS-W2 22" 1920x1080 2MS VGA DVI-D HDMI LED
£154.39
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered on Monday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • HAS + Pivot
  • OverDrive on/off
  • ACR
  • Full HD
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £157.88
Save £1.50
The ProLite B2480HS is a high specification 24" Full HD 1920 x 1080p LED-backlit monitor with Height Adjustability and Screen Rotation allowing you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort. 2msec response time and 12 000 000: 1 Advanced Contrast Ratio make the B2480HS ideal for Video Conferencing, DTP and CAD as well as the usual text based applications. Triple Input support of analog, DVI and HDMI ensures compatibility with the installed graphics cards and embedded Notebook outputs. The monitor is Energy Star and TCO Certified.
Product Description iiyama ProLite B2480HS-W2 - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A
Energy Consumption per Year 32 kWh
Power Consumption (On mode) 21.8 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.2715 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 12000000:1 (dynamic)
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Dimensions (WxDxH) - with stand 57.15 cm x 24.45 cm x 42.7 cm
Weight 6.1 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, DDC-2B, VESA DPMS
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite B2480HS...
£154.39
