General |
Display Type |
LED-backlit LCD monitor / TFT active matrix |
Energy Class |
Class A |
Energy Consumption per Year |
32 kWh |
Power Consumption (On mode) |
21.8 W |
Diagonal Size |
24" |
Viewable Size |
23.6" |
Panel Type |
TN |
Aspect Ratio |
16:9 |
Native Resolution |
Full HD (1080p) 1920 x 1080 |
Pixel Pitch |
0.2715 mm |
Brightness |
250 cd/m² |
Contrast Ratio |
1000:1 / 12000000:1 (dynamic) |
Colour Support |
16.7 million colours |
Vertical Refresh Rate |
56 - 75 Hz |
Horizontal Refresh Rate |
24 - 80 kHz |
Horizontal Viewing Angle |
+85 / -85 |
Vertical Viewing Angle |
+80 / -80 |
Backlight Technology |
LED backlight |
Controls & Adjustments |
Volume, brightness, contrast, H/V position, gamma correction, colour temperature, phase, clock, aspect control |
OSD Languages |
English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese |
Features |
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), i-Style Color |
Dimensions (WxDxH) |
57.15 cm x 24.45 cm x 42.7 cm - with stand |
Weight |
6.1 kg |
Audio |
Type |
Speakers - stereo |
Output Power / Channel |
2 Watt |
Connectivity |
Interfaces |
DVI-D , VGA , HDMI , Audio line-in |
Mechanical |
Display Position Adjustments |
Height, pivot (rotation), swivel, tilt |
Tilt Angle |
-5/+22 |
Swivel Angle |
320 |
Rotation Angle |
90 |
Height Adjustment |
130 mm |
VESA Mounting Interface |
100 x 100 mm |
Miscellaneous |
Features |
Security lock slot (cable lock sold separately) |
Included Accessories |
Stand, cable management cover |
Cables Included |
1 x DVI cable , 1 x audio cable |
Compliant Standards |
TUV GS, DDC-2B, VESA DPMS |
Power |
Voltage Required |
AC 120/230 V (50/60 Hz) |
Power Consumption Operational |
22 Watt |
Power Consumption Stand by |
0.5 Watt |
Software / System Requirements |
OS Required |
Microsoft Windows 95/98/ME/2000/XP/Vista/7/8, Windows 10 |
Dimensions & Weight |
Dimensions & Weight Details |
With stand - width: 57.15 cm - depth: 24.45 cm - height: 42.7 cm - weight: 6.1 kg , Without stand - width: 57.15 cm - depth: 4.95 cm - height: 35.1 cm |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Environmental Parameters |
Min Operating Temperature |
5 °C |
Max Operating Temperature |
35 °C |
Humidity Range Operating |
10 - 80% (non-condensing) |
