iiyama ProLite B2482HS-B1 24" 1920x1080 1ms HDMI DVI VGA...
iiyama ProLite B2482HS-B1 24" 1920x1080 1ms HDMI DVI VGA LED Monitor
£151.84
23 in stock
Delivery:
Standard: 3-5 working days
Key features
  • Full HD
  • Height adjustable stand with pivot function
  • Flicker-free monitor with blue light reducer function
  • Integrated speakers
  • Advanced Contrast Ratio (ACR)
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, HDMI, VGA (HD-15)
Product codes
The ProLite B2482HS is an excellent 24" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 1ms response time and 80 000 000:1 Advanced Contrast Ratio, assuring clear and vibrant picture quality and high contrast. The ergonomic stand offers height adjustment with pivot and swivel, making this screen suitable for a wide range of applications and environments where workplace flexibility and ergonomics are key factors. A perfect solution for education, local government, business and finance markets.
Product Description iiyama ProLite B2482HS-B1 - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A
Energy Consumption per Year 36 kWh
Power Consumption (On mode) 24.9 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.277 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 80000000:1 (dynamic)
Response Time 1 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI, VGA
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Matte
Colour Black
Dimensions (WxDxH) 56.55 cm x 23 cm x 38.65 cm
Weight 5.1 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, DDC-2B, DDC/CI, RoHS, WEEE, PSE Mark, VCCI Class B
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been repaired under warranty by the manufacturer
Ref: DQ5F 041441
£67.65
product
Ref: DQ5F 041441
Accessories
Packaging
Functional
Software
Manuals
£67.65
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite B2482HS...
£151.84
