iiyama ProLite B2483HSU-B1DP 24" 1920x1080 2ms VGA DVI-D...
iiyama ProLite B2483HSU-B1DP 24" 1920x1080 2ms VGA DVI-D DisplayPort LED Monitor
£157.33
22 in stock
Delivery:
Standard: 1-3 working days
Key features
  • ACR
  • HAS + Pivot
  • Speakers and headphones
  • Flicker free
  • Overdrive On / Off
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, VGA (HD-15)
Product codes
The ProLite B2483HSU is an excellent 24" Full HD LED-backlit monitor. Triple Input (incl. DisplayPort) support and USB HUB ensure compatibility with the latest installed graphics cards and embedded Notebook outputs. The ergonomic stand offers 13 cm height adjustment with pivot and swivel, making this screen suitable for a wide range of applications and environments where workplace flexibility and ergonomics are key factors. The monitor is TCO6 and Energy Star Certified. A perfect solution for education, local government, business and finance markets.
Product Description iiyama ProLite B2483HSU-B1DP - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Features USB 2.0 hub
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.277 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 12000000:1 (dynamic)
Response Time 1 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA, DisplayPort
Speakers Integrated
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) 56.55 cm x 23 cm x 38.65 cm
Weight 5.2 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, DDC-2B, VESA DPMS, TCO Displays 6.0, VCCI Class B
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite B2483HS...
£157.33
