General |
Display Type |
LED-backlit LCD monitor / TFT active matrix |
Diagonal Size |
24" |
Built-in Devices |
USB 2.0 hub |
Panel Type |
TN |
Aspect Ratio |
16:9 |
Native Resolution |
Full HD (1080p) 1920 x 1080 |
Pixel Pitch |
0.277 mm |
Brightness |
250 cd/m² |
Contrast Ratio |
1000:1 / 12000000:1 (dynamic) |
Colour Support |
16.7 million colours |
Response Time |
1 ms |
Vertical Refresh Rate |
55 - 75 Hz |
Horizontal Refresh Rate |
30 - 80 kHz |
Horizontal Viewing Angle |
+85 / -85 |
Vertical Viewing Angle |
+80 / -80 |
Backlight Technology |
LED backlight |
Controls & Adjustments |
Mute, volume, brightness, contrast, H/V position, sharpness, input select, phase, clock, luminance |
OSD Languages |
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese |
Features |
HDCP, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology |
Colour |
Black |
Dimensions (WxDxH) |
56.55 cm x 23 cm x 38.65 cm |
Weight |
5.2 kg |
Audio |
Type |
Speakers - stereo - integrated |
Output Power / Channel |
1 Watt |
Connectivity |
Interfaces |
DVI-D (HDCP) , VGA , DisplayPort (HDCP) , Headphones , 2 x USB 2.0 downstream , USB 2.0 upstream |
Mechanical |
Display Position Adjustments |
Height, pivot (rotation), swivel, tilt |
Tilt Angle |
-5/+22 |
Swivel Angle |
90 |
Rotation Angle |
90 |
Height Adjustment |
130 mm |
VESA Mounting Interface |
100 x 100 mm |
Miscellaneous |
Features |
Security lock slot (cable lock sold separately) |
Included Accessories |
Stand |
Cables Included |
1 x DVI cable , 1 x audio cable |
Compliant Standards |
TUV GS, DDC-2B, VESA DPMS, VCCI Class B |
Power |
Power Supply |
Internal |
Voltage Required |
AC 120/230 V (50/60 Hz) |
Power Consumption Operational |
23 Watt |
Power Consumption Stand by |
0.5 Watt |
Software / System Requirements |
Included Software |
Drivers & Utilities |
OS Required |
Apple MacOS, Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista / 7 / 8 |
Environmental Standards |
ENERGY STAR Certified |
Yes |
