We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The ProLite B2483HSU is an excellent 24" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 1ms response time and 80000000: 1 Advanced Contrast Ratio, assuring clear and vibrant picture quality and high contrast. Triple input support ensures compatibility with the graphics cards and embedded notebook outputs. The ergonomic stand offers 13 cm height adjustment with pivot, swivel and tilt, making this screen suitable for a wide range of applications and environments where workplace flexibility and ergonomics are key factors.
Product Description | iiyama ProLite B2483HSU-B5 - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class E | Energy Consumption per Year | 28 kWh | Power Consumption (On mode) | 18.1 W | Features | USB 2.0 hub | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.277 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 80000000:1 (dynamic) | Response Time | 1 ms | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC, 99% sRGB | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Matte | Voltage | AC 120/230 V (50/60 Hz) | Colour | Matte black | Dimensions (WxDxH) | 56.55 cm x 21 cm x 37.55 cm | Weight | 5.1 kg | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Silver | Compliant Standards | TUV GS, DDC-2B, PSE Mark, VCCI Class B, EAC, CU, REACH SvHC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Built-in Devices | USB 2.0 hub |
Panel Type | TN |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 31 - 85 kHz |
Horizontal Viewing Angle | +85 / -85 |
Vertical Viewing Angle | +80 / -80 |
Backlight Technology | LED backlight |
OSD Languages | Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese |
Features | HDCP, High Frame Rate Control (Hi-FRC), Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, 72% NTSC colour gamut, 99% sRGB colour gamut |
Weight | 5.1 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1 Watt |
Connectivity | |
Interfaces | VGA , DisplayPort , HDMI , Headphones , 2 x USB 2.0 |
Mechanical | |
Tilt Angle | -5/+22 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Stand |
Cables Included | 1 x USB cable , 1 x HDMI cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 18.1 kWh/1000h |
Power Consumption (Typical) | 18 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
EPEAT Compliant | EPEAT Silver |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
