Looking at a screen for long hours can be quite tiring for the eyes. But it doesn't have to. The Iiyama ProLite B2791HSU is big enough to make sure you can clearly see every detail and it comes equipped with technologies to help keep your vision intact. The panel backlight is flicker free and the blue light reducer function limits the amount of blue, the unfavorable, light emitted by the screen. The height adjustable stand allows you to easily adjust the screen position to make sure you are looking at it at the right angle.
Product Description | iiyama ProLite B2791HSU-B1 - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class E | Energy Consumption per Year | 29 kWh | Power Consumption (On mode) | 19.7 W | Adaptive-Sync Technology | AMD FreeSync | Features | USB 2.0 hub | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz) | Pixel Pitch | 0.311 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 12000000:1 (dynamic) | Response Time | 1 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Matte | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 61.35 cm x 23 cm x 39.75 cm | Weight | 6.9 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | TUV GS, DDC-2B, VESA DPMS, CU | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | USB 2.0 hub |
Panel Type | TN |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | +85 / -85 |
Vertical Viewing Angle | +80 / -80 |
Backlight Technology | LED backlight |
OSD Languages | English, German, French, Italian, Polish, Russian, Spanish, Japanese, Chinese |
Features | HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, i-Style Color, Black Tuner |
Colour | Black |
Dimensions (WxDxH) | 61.35 cm x 23 cm x 39.75 cm - with stand |
Weight | 6.9 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DisplayPort , HDMI , Audio line-in , 2 x USB 2.0 downstream , USB 2.0 upstream , Headphones |
Mechanical | |
Tilt Angle | -5/+22 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x HDMI cable , 1 x USB cable |
Mounting Kit | Included |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 19 kWh/1000h |
Power Consumption (Typical) | 19 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
OS Required | Apple MacOS, Microsoft Windows |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 61.35 cm - depth: 5.4 cm - height: 37.05 cm , With stand - width: 61.35 cm - depth: 23 cm - height: 39.75 cm - weight: 6.9 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
