iiyama ProLite B2791HSU-W1 27" 1920x1080 1ms VGA HDMI...
1ms VGA HDMI DisplayPort LED Monitor
£196.12
41 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Has + pivot
  • FreeSync technology
  • Speakers and headphones
  • ACR
  • Diagonal Size: 27in
  • Max Resolution: 1920 x 1080
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
Looking at a screen for long hours can be quite tiring for the eyes. But it doesn't have to. The Iiyama ProLite B2791HSU is big enough to make sure you can clearly see every detail and it comes equipped with technologies to help keep your vision intact. The panel backlight is flicker free and the blue light reducer function limits the amount of blue, the unfavorable light emitted by the screen. The height adjustable stand allows you to easily adjust the screen position to make sure you are looking at it at the right angle.
Product Description iiyama ProLite B2791HSU-W1 - LED monitor - Full HD (1080p) - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A+
Energy Consumption per Year 29 kWh
Power Consumption (On mode) 19.7 W
Adaptive-Sync Technology AMD FreeSync
Features USB 2.0 hub
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz)
Pixel Pitch 0.311 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 12000000:1 (dynamic)
Response Time 1 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Matte
Colour White
Dimensions (WxDxH) - with stand 61.35 cm x 23 cm x 39.75 cm
Weight 6.9 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, DDC-2B, VESA DPMS, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite B2791HS...
£196.12
