iiyama ProLite B2791QSU-B1 27" 2560 x 1440 1ms DVI HDMI...
iiyama ProLite B2791QSU-B1 27" 2560 x 1440 1ms DVI HDMI LED Monitor
£225.33
32 in stock
Delivery:
Standard: 1-3 working days
Key features
  • WQHD
  • HAS + Pivot
  • Flicker free + Blue light
  • Diagonal Size: 27in
  • Max Resolution: 2560 x 1440
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI
Product codes
Looking at a screen for long hours can be quite tiring for the eyes. But it doesn't have to. The 27" iiyama ProLite B2791QSU is big enough to make sure you can clearly see every detail and it comes equipped with technologies to help keep your vision intact.
The B2791QSU offers WQHD (2560 x 1440) resolution meaning the screen can accommodate almost 77% more information than a Full HD display. Email and excel will fit in nicely next to each other. The panel backlight is flicker free and the blue light reducer function limits the amount of blue, the most unfavorable, light emitted by the screen.
The height adjustable stand allows you to easily adjust the screen position to make sure you are looking at it at the right angle. DVI, HDMI and DisplayPort inputs along with a USB hub assure broad connectivity options. And as the monitor offers 1 ms response time and supports FreeSync technology, it can serve not only as your workplace companion, but also to play games and watch movies.
Product Description iiyama ProLite B2791QSU-B1 - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class G
Energy Consumption per Year 52 kWh
Power Consumption (On mode) 28.8 W
Adaptive-Sync Technology AMD FreeSync
Features USB 3.0 hub
Panel Type TN
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440 (DisplayPort: 75 Hz, HDMI: 70 Hz, DVI: 60 Hz)
Pixel Pitch 0.223 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 80000000:1 (dynamic)
Response Time 1 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DVI, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Matte
Voltage AC 120/230 V (50/60 Hz)
Colour Black
Dimensions (WxDxH) - with stand 61.1 cm x 23 cm x 39.7 cm
Weight 6.1 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, VESA DPMS, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£225.33
